Prostar chicken light wiring? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Prostar chicken light wiring? (/showthread.php?tid=5753) |
Prostar chicken light wiring? - Jprps - 01-28-2020 Hey guys real quick do you know if my 2011 Prostar has wiring for chicken/clearance lights like a pete does? Or would I have to wire them into the existing light wiring so they come on with the side markers? Thanks in advance. RE: Prostar chicken light wiring? - barf - 01-28-2020 My '09 has a switch on the dash that says 'spare' and is connected to nothing; it's what I would use. If you don't have a switch like that, add one yourself, or like you said - wire them into the existing... RE: Prostar chicken light wiring? - Brock - 01-28-2020 Look behind the panel below your bunk or under your drivers door for a plug. Also pull out your panel with your switches and look for a plug that isnt plugged in that says marker lights or skirt lights.. Odds are it's all there. RE: Prostar chicken light wiring? - Jprps - 01-28-2020 Coolio, thanks fellas! |
