| where to tap in voltage meter - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: where to tap in voltage meter (/showthread.php?tid=5780) |
where to tap in voltage meter - hookliftpete - 02-05-2020 On my Pete 335, the original owner did not spec it with a voltage meter. I'd like to add one when I put my pyro and boost on. Best to wire it directly off the main battery leads? RE: where to tap in voltage meter - tree98 - 02-05-2020 I think that's exactly what I would do. That way your getting information right from the source. RE: where to tap in voltage meter - Lonestar10 - 02-05-2020 At batteries is best. Or off starter stud as second choice. Make sure to fuse it at the source with at min a 1 amp fuse 10amp max RE: where to tap in voltage meter - hookliftpete - 02-05-2020 Conveniently the batteries are sealed agm and happen to be under the passenger seat. Would make it easy to wire into. Thanks! |
