| Manual fan switch - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Manual fan switch (/showthread.php?tid=580) |
Manual fan switch - Mrkentee - 07-04-2016 My 2010 386 had no manual fan switch. But there was a plug hanging behind the dash for it. I bought a switch and installed it. The problem is: the cab controller recognizes the switch. You can see it turn on and off with PACAR ESA program. But the ecm doesn't see it. If you enable the switch function in INSITE the fan runs continuously, meaning it thinks the switch has malfunctioned. I had someone experienced with this look at it, and they said something in the drop down menu from the switch option in INSITE is missing. That's as far as they went at the time. Anyone have any idea where to go from here? RE: Manual fan switch - Rawze - 07-04-2016 (07-04-2016 )Mrkentee Wrote: My 2010 386 had no manual fan switch. But there was a plug hanging behind the dash for it. I bought a switch and installed it. The fan switch in the ECM most likely needs the J1939 address for it assigned to it. I think this can usually be done in Insite, but you need to know the correct adress for it. RE: Manual fan switch - Unilevers - 07-04-2016 it needs to be set on 49 - cab controller in insite to function correctly. RE: Manual fan switch - Mrkentee - 07-04-2016 (07-04-2016 )Unilevers Wrote: it needs to be set on 49 - cab controller in insite to function correctly. I did that. I enabled it in two places snd made sure the address was correct. Still acts like it doesn't see the switch. RE: Manual fan switch - Mrkentee - 07-05-2016 Still no luck. RE: Manual fan switch - Rawze - 07-06-2016 All MM tuned trucks should have the code blocked so that you can install a manual fan switch into the ground wire of the solenoid, other than that,... On a stock truck, just buy a second solenoid for the fan clutch and install it into the air-line for it. That is the easiest way without getting it re-programmed. RE: Manual fan switch - biscuits and gravy - 07-06-2016 [attachment=1665] If you can see that black wire and red running together into that black connector; that black ground wire is the one to splice into and connect to a new switch in the dash for a manual fan switch. If your running @m*m^2. RE: Manual fan switch - Mrkentee - 07-06-2016 Thanks. I thought that might be the case. I have the actual switch in the dash and would like it to work properly. Maybe Gearhead can straighten it out when I go for my overhead adjustment in a few thousand miles. RE: Manual fan switch - gearhead - 07-08-2016 yes if you bring it buy i can get it hooked up for you. |
