Obtaining tow hooks - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Obtaining tow hooks (/showthread.php?tid=5823) |
Obtaining tow hooks - Mattman - 02-13-2020 Anyone have a source to get tow hooks for a T660? Seen a fellow driver in a bind without a tow hook, figured I need to get me at least one of not two. Been nice if manufacturer had of factory installed something wether it be a hook or a shackle to begin with. Found some on eBay, they are priced like gold. RE: Obtaining tow hooks - smorgan87 - 02-13-2020 Dunno about the t660 but my prostar has removable hooks that latch into slots behind the bumper. They about $150 for a set if i remember right. Was gonna weld some 40k lb d rings on my old one b4 i traded up and the new one had a set. RE: Obtaining tow hooks - Lonestar10 - 02-13-2020 truck salvage yard. RE: Obtaining tow hooks - Mattman - 02-13-2020 (02-13-2020 )smorgan87 Wrote: Dunno about the t660 but my prostar has removable hooks that latch into slots behind the bumper. They about $150 for a set if i remember right. Was gonna weld some 40k lb d rings on my old one b4 i traded up and the new one had a set. T660 has square tube that tow hook slides into and you put a round pin thru a hole behind the bumper to secure tow hook. Like a receivers hitch. RE: Obtaining tow hooks - Chamberpains - 02-14-2020 I've seen guys make their own with square stock. Or you may find a tow hook at Tractor supply that'll probably work. If not Lonestar10 has the right idea. RE: Obtaining tow hooks - ynot - 02-14-2020 Like lonestar said hit up a junk yard for some, i don't know bout t660's but any w9 ive had theu came with 2 tow hooks from the factory usually stored under the bunk |
