Cm871 repeated same injector failure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm871 repeated same injector failure (/showthread.php?tid=589) |
RE: Cm871 repeated same injector failure - Inderjit - 07-06-2016 (07-06-2016 )Rawze Wrote: Did anyone bother to boroscope the engine properly when it was replaced the first time?Everything is stock. I change oil every 10k miles. Half a gallon oil use every 10 k. 2637 fc is there when i check for codes. 1117 fc for ecm data erratic is 90% of the time there with 2637. RE: Cm871 repeated same injector failure - Inderjit - 07-06-2016 I get big puff of white smoke when shifting gears. Idling fluctuates when cold during morning RE: Cm871 repeated same injector failure - Inderjit - 07-06-2016 Yes STEALERSHIP assured me nothing is wrong with injector hole. Supposedly they boroscoped it. Who knows But i am not losing any coolant. Every time i have fc2637 90% of the time 1117 fc is also there. It is for ecm data erratic or intermitent RE: Cm871 repeated same injector failure - Inderjit - 07-06-2016 Yes rawze leak test reveals inj 6 leaking air every time RE: Cm871 repeated same injector failure - Rawze - 07-06-2016 Sounds to me like possibly a crack in the head or or something. Have you tried swapping injectors and simply replacing o-rings to see what happens? Does the cam/rollers look good? Are any of the valves sitting high in their seat? What is the detent clearance after setting the engine brake rocker correctly? I am thinking that there is more to it that someone just hasn't caught, or perhaps something that is not being done correctly? It could be running hot in only one cylinder,.. has anyone checked the thermal difference of the cylinders? Has anyone pulled the intake manifold off and inspected it for soot packing? -- Maybe it is getting starved of air? or a blockage in the exhaust manifold? RE: Cm871 repeated same injector failure - in2trux - 07-06-2016 Rawze is always thinking! Are you putting the new injector in #6 or moving an old one? By now you should have all new injectors! If you move one from another cylinder and it fails that is a symptom, not the problem. Is the same shop doing the troubleshooting? Leak test should have been done already. It seems that at 500k, just when warranty runs out lot's of problems surface. That is the beauty of this forum, shared experience with the same engine. The whole lot of us have seen lots of problems and have worked past them. I would be looking at the injector harness. Replacing 2 rear bank fueling and metering actuators would be throwing money at it but you're going to need them sooner rather than later. The 2637 code will haunt you constantly. The white puffs of smoke are from it trying to regen, unless the doser is leaking fuel or coolant. Ultimately there is only, the final solution, if you want to keep your sanity and make money. RE: Cm871 repeated same injector failure - Waterloo - 07-06-2016 I had a bad head on my CM871, it did not use any oil between oil changes, and the only coolant loss I had was due to internal pressure of the exhaust gas building in my motor, which forced the coolant out of the lines at the clamps. So, in other words, you don't always have coolant or oil loss with a bad head. If you take it in to another shop, stand there and babysit them, or better yet, get the truck to someone like Gearhead that knows what he is doing. I feel for you buddy, this sucks. RE: Cm871 repeated same injector failure - Inderjit - 07-06-2016 (07-06-2016 )Rawze Wrote: Sounds to me like possibly a crack in the head or or something. Have you tried swapping injectors and simply replacing o-rings to see what happens?Intake manifold is good because i did the egr tuneup new doser new sensors RE: Cm871 repeated same injector failure - Inderjit - 07-06-2016 (07-06-2016 )Rawze Wrote: Sounds to me like possibly a crack in the head or or something. Have you tried swapping injectors and simply replacing o-rings to see what happens?Stealership do the leak test finds a leaking injector and send me on my way |
