Cm870 built with CM 570 internals. - Printable Version
+--- Thread: Cm870 built with CM 570 internals. (/showthread.php?tid=5939)
Pages: 1 2
RE: Cm870 built with CM 570 internals. - SC Josh - 03-08-2020
Is mr haggi still around here? I left a message on his shop phone a month or so back, but I never received a call back.
(03-08-2020 )Brock Wrote:  I'm not hung up on anything, I dont care that you went through a turbo and a head..... completely normal with your torque loads. Your preaching to the choir with me man, I live in Grande Praire Ab and have always hauled 100,000 to 160,000lbs...... always, so I know what your talking about.
I was considering going to a 16:1 on my c15 and throwing the 18:1 away but decided to run a ISX871 instead.
What kind of big power are you talking? If your going around 600 or 625 then I would see no need to lower compression as the ISX engines dont really have head pressure issues that I'm aware of and the bigger CPL engines were built for 600 anyways.
As far as the Variable turbo, once again, talk to Hammer and ask him how the Blue Ox exhaust brake he has has been holding up, last I spoke to him he said the thing hits hard, not quite as well as his VG but still real good..... it has been a bit since we spoke though.
Now all of this is just my opinion, its apparent that you have a different one and seem to have already made up your mind. I have zero working knowledge of the internals of the 570 or even what their compression ratios are. If you are wanting real high horsepower then there are s multitude of things you can do, lower your compression ratio, big turbo, new cam etc aussie spec the engine basically.
You may be right. I may not need to do anything different. I would love to build it Aussie spec, but 625 or 650 I could live with. I wasn’t aware that hammer swapped out his VG, it’s been a while since I’ve talked to him. I don’t want to get too crazy as it’s still a working truck and I want it to last, so I’m not thinking 8 or 900 hp. Maybe 700 max.
RE: Cm870 built with CM 570 internals. - Signature620 - 03-08-2020
It's certainly not impossible to build an 870 with 570 pistons but the end result would not justify the headaches and costs. If you bought an 870 o/haul kit and a set of 570 pistons, you'll spend a fair bit more and have 6 870 piston kits you'll never need. If you buy a 570 o/haul kit, half the gaskets won't fit. The 570 pistons will also require a different part number injector - Which you won't have any cores for. They may also require a different injector cam. On top of that, the new injectors would need a completely different set of maps in the ECM to run correctly. By the time you're done, you could've just rebuilt it as it is and gotten the power increased and/or VG removed.
As Brock said, 870s don't really suffer from excessive cylinder pressure. As with any ISX - It's all in the injection timing & liner protrusion.
(03-08-2020 )Signature620 Wrote:  It's certainly not impossible to build an 870 with 570 pistons but the end result would not justify the headaches and costs. If you bought an 870 o/haul kit and a set of 570 pistons, you'll spend a fair bit more and have 6 870 piston kits you'll never need. If you buy a 570 o/haul kit, half the gaskets won't fit. The 570 pistons will also require a different part number injector - Which you won't have any cores for. They may also require a different injector cam. On top of that, the new injectors would need a completely different set of maps in the ECM to run correctly. By the time you're done, you could've just rebuilt it as it is and gotten the power increased and/or VG removed.
Thank you for your reply. This is the kind of information I was looking for. What gaskets wouldn’t fit? I was under the impression that the 870 and 570 were virtually identical except for the egr and egr cooler.
The exhaust manifold, turbo, thermostat housing and ECM cooling plate gaskets will be different. There will be some gaskets missing as well like the EGR cooler inlet one.
RE: Cm870 built with CM 570 internals. - Unilevers - 03-08-2020
i have physically done this conversion, and it was 100% not worth it. The cams are the same if you have a big CPL 870, but thats about it. The injectors, turbo, manifold, IFSM, ecm, etc etc are all different. you have to piece together a kit manually.
In the end just buy a set of IPD 870 steel liners and pistons, decide what your turbo setup and torque loads and desired HP are going to be, and have it built and tuned properly. 870's can handle high power fairly well.
RE: Cm870 built with CM 570 internals. - SC Josh - 03-09-2020
(03-08-2020 )Unilevers Wrote:  i have physically done this conversion, and it was 100% not worth it. The cams are the same if you have a big CPL 870, but thats about it. The injectors, turbo, manifold, IFSM, ecm, etc etc are all different. you have to piece together a kit manually.
Thanks! That will save a lot of headache and money. I sent you a pm. I still need to get it retuned and want a second ecm.
