Speed/Tach Sensor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Speed/Tach Sensor (/showthread.php?tid=5947) |
Speed/Tach Sensor - RocketScott - 03-09-2020 My speedo stopped working, tracked the problem to the speed sensor. When I bought the truck five years ago the speed sensor was coming apart, so I epoxied it back together and carried on. It's coming apart again and should replace it this time (the epoxy was a temp fix, but I forgot about it, so here we are five years later...) The build sheet shows Peterbilt part number 16-04117 for both the speedo and tach sensors. I can't find a cross for that. It's 3/4-16" threads that are 2-1/2" long. The leads are 18" with an old style connector that isn't weatherproof What I need is the same sensor with the same length leads and a modern weather tight connection (weather-pack/metri-pack). I can replace the chassis harness connector to match the new sensor. Already have a bunch of weather-pack connectors so that would be preferred The truck is an '89 Peterbilt 379 with a Cummins 444xt and Eaton 18spd RT0 Also - Could someone remind me the procedure for setting it? I know it gets screwed in till it touches then backed off a certain amount. Just can't remember how much RE: Speed/Tach Sensor - Rtrucking - 03-09-2020 1/4 to 1/2 if I remember correctly but I could be wrong on it RE: Speed/Tach Sensor - RocketScott - 03-09-2020 1/4-1/2 turn or 1/4-1/2"? 1/4" sounded about right but I couldn't remember RE: Speed/Tach Sensor - Nilao - 03-09-2020 Half a turn out. At a quarter inch it'll never read anything. |
