CM 2250 sensor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM 2250 sensor (/showthread.php?tid=60) |
CM 2250 sensor - snailexpress - 02-25-2016 Please help me identify what sensor is this? Today was performing visual check and found wire is almost gone RE: CM 2250 sensor - gearhead - 02-25-2016 Thats the wire to your block heater. When you plug in your truck this heats the coolant. RE: CM 2250 sensor - jorden486 - 02-26-2016 Good eye catching that. I always watch for the tiny spark or listen for the click when you plug the block heater in to verify its working. |
