Isx 15 2350 valve lash - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Isx 15 2350 valve lash (/showthread.php?tid=6027) |
Isx 15 2350 valve lash - Blackfoot - 04-01-2020 First time poster here. I have a 2014 cummins ISX 15 2350 and I'm wondering if the valve lash is the same for all ISX engines or is the lash different on this model? Have seen several youtube videos that differ in the clearance for this engine. Thanks in advance. Blackfoot RE: Isx 15 2350 valve lash - Mattman - 04-01-2020 Should be wrote on your valve cover. RE: Isx 15 2350 valve lash - Blackfoot - 04-01-2020 Thank you! I'll check right now. RE: Isx 15 2350 valve lash - Rawze - 04-02-2020 STOP WATCHING YOUTUBE GARBAGE!!!!! -- REGISTER YOUR ENGINE ON QUICKSERV.COM ... ALL THE PROCEDURES AND PROPER SETTINGS ARE THERE! IT IS ABSOLUTELY FREE! Intake on the ISX CM870, CM871, CM2250, and CM2350-X101 is 0.014" (some guys will use 0.015", this is ok too), the exhaust valves are 0.027", and the engine brake is 0.276". Go look it up for yourself on quickserv using your enigne ser# to be sure about it!. RE: Isx 15 2350 valve lash - Chamberpains - 04-02-2020 https://quickserve.cummins.com/info/index.html In case you didn't know where to look. RE: Isx 15 2350 valve lash - Blackfoot - 04-02-2020 (04-02-2020 )Rawze Wrote: STOP WATCHING YOUTUBE GARBAGE!!!!! -- REGISTER YOUR ENGINE ON QUICKSERV.COM ... ALL THE PROCEDURES AND PROPER SETTINGS ARE THERE! Thanks for the help Rawze, Just got registered with Quickserve. Took a short spin on their site and found all I need to know. Thanks again. OH! by the way, I would stop watching YouTube garbage, But most of what I watch are your videos lol. RE: Isx 15 2350 valve lash - Blackfoot - 04-02-2020 (04-02-2020 )Chamberpains Wrote: https://quickserve.cummins.com/info/index.html Thank you for replying. I did get registered with Quickserve. Thanks for the nudge in the right direction. RE: Isx 15 2350 valve lash - Rawze - 04-02-2020 (04-02-2020 )Blackfoot Wrote: ... my claims of not trusting garbage YouTube videos includes mine as well, I go out of my way to post the best info I can at the time of making ... I try to be as informative as possible, but a person should always take them with a grain of salt. -- I am no professionally trained, nor certified mechanic, never claimed to be. LOL RE: Isx 15 2350 valve lash - JimT - 04-02-2020 (04-02-2020 )Rawze Wrote: I am no professionally trained, nor certified mechanic, never claimed to be. LOL No your not, which is why you and your advice have been so valuable to so many people! |
