Metering actuator question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Metering actuator question (/showthread.php?tid=6110) |
Metering actuator question - Brock - 04-23-2020 Anyone ever seen this? The one metering actuator has o-rings instead of a gasket and it. Cummins looked up part numbers and old ones from a cm570, 870 and 871 and cant find one that didnt have a gasket. [attachment=6540][attachment=6539] RE: Metering actuator question - marek4792 - 04-23-2020 My CM870 had one apparently the metal gasket is supposed to work with the old style actuator too don't take my word on it though. RE: Metering actuator question - Unilevers - 04-23-2020 very early ones had o-rings like that - then they went to newer style updated with the metal gasket. RE: Metering actuator question - Lonestar10 - 04-23-2020 The 870 style ifsm I put on my 871 had clean marks that clearly showed it had oring actuators on it. Saw several ifsm units in the salvage yard Cummins box where I found mine but all the others had a different filter base on them that took alot bigger filters and had different sized threaded filter nipple. |
