Power surge on CM870??? - Printable Version
+--- Thread: Power surge on CM870??? (/showthread.php?tid=6132)
Pages: 1 2 3
RE: Power surge on CM870??? - Rawze - 05-16-2020
(05-16-2020 )4lanefarmall Wrote:  Yah, I didn't suggest anything, the leak down test was the first they did. (Surprisingly)
It should have been the second thing they did, as you will almost always get false positives if the overhead valves and especially if the injectors have not been recently re-adjusted before doing the leak-down test.
