exhaust pressure sensing tube - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: exhaust pressure sensing tube (/showthread.php?tid=6218) |
exhaust pressure sensing tube - Konstantin - 05-30-2020 Hi guys, I am changing exhaust manifold gaskets and run into a problem. I was not able to unscrew exhaust pressure sensing tube from both manifold and exhaust pressure sensing housing. After heating tube unscrewed from the housing but not from manifold. I left it hanging there. So , I changed gaskets, bolts , etc and now I think I have damaged threads in the housing. Anybody knows what to do? Maybe you know what kind of thread it is? I do not know for sure but it looks to me metric M12 1.0 . Thanks! RE: exhaust pressure sensing tube - the missing link - 05-30-2020 When I changed mine ,I ended up having to cut the type to put a socket on it . Then I just bought a new one . RE: exhaust pressure sensing tube - Rawze - 05-30-2020 When they are stuck like that, cut the pipe part off it then take your time heating it up until the whole fitting is glowing a nice dull red on its own... use a 6-point socket on it, work it back and fourth a little at a time until it comes out. RE: exhaust pressure sensing tube - Konstantin - 05-31-2020 thank you, that is what i will do. i will give it last chance and if it is stuck will just replace it RE: exhaust pressure sensing tube - JimT - 05-31-2020 same here. mine was so rusted in place that it was bending my open ended wrench trying to turn it. eventually ordered a new pipe then cut the old one and threw a socket on there. didn't need heat, just broke it free and it came right out. RE: exhaust pressure sensing tube - tree98 - 05-31-2020 Line wrenches are handy for this. RE: exhaust pressure sensing tube - Konstantin - 06-01-2020 (05-31-2020 )tree98 Wrote: Line wrenches are handy for this.i have one , but no luck, today i will just cut it off ))) |
