| 2010 t660 cm871 10 micron primary filter - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: 2010 t660 cm871 10 micron primary filter (/showthread.php?tid=6228) |
2010 t660 cm871 10 micron primary filter - Chamberpains - 06-02-2020 I just bought this truck and it has the frame mount spin on primary fuel filter FF2203 140 micron. Im looking to replace it with a 10 micron filter. Does anyone know of a 10 micron spin on filter or am I gonna need to mount a Davco system? I found a spin on marine application fuel/water separator part# fs1013 but I have no idea whether it'll fit on the current filter mount. I also don't understand why KW doesn't have some sort of water separator from factory. Any help would be appreciated. RE: 2010 t660 cm871 10 micron primary filter - Rawze - 06-02-2020 here is the one i use in my Davco... https://amzn.to/2U2PiLQ filter p# FS19727 (Fleetguard). |
