Fault code 1942 crankcase pressure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Fault code 1942 crankcase pressure (/showthread.php?tid=6232) |
Fault code 1942 crankcase pressure - Paccardude - 06-03-2020 Hello all, The check engine light recently came on . My engine isx15 2350 had dumped a lot of oil all at once. There was no signs of visible leaking. I opened the crankcase filter and had oil all in the filter. I removed the filter and hooked up Cummins insite. Fault 1942 crankcase pressure sensor erratic. The dumping of oil only happened once I noticed the turbo sounding a bit off, only while idling. There's no coolant leaking , no oil leaking, however, I have noticed a significant decrease in fuel economy. Check light cleared and 3 days later it emerged again. Any one have a clue as to what's going on? RE: Fault code 1942 crankcase pressure - Rawze - 06-03-2020 see how much blo=-by you have. maybe drill out the CC filter or replace it with a maintenance free one from cummins ... http://rawze.com/forums/showthread.php?tid=65&pid=376#pid376 is the truck de-mandated? - if so, who did the engine tuning, etc? RE: Fault code 1942 crankcase pressure - Paccardude - 06-04-2020 The truck is mandated. I'll check for blo-by as soon as I get home. RE: Fault code 1942 crankcase pressure - Rawze - 06-04-2020 (06-04-2020 )Paccardude Wrote: The truck is mandated. I know its kinda red-neck ... but this is better than taking it to a dyno and spending a lot of money just to see if you got blo-by issues... |
