Bacon SAVED! - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Bacon SAVED! (/showthread.php?tid=6340) |
Bacon SAVED! - fargonaz - 06-28-2020 Just wanted to stop by and say thanks to all for their contributions. Had an Annual Inspection coming down to the wire, tech failed(as he should have) for a pretty big air leak. He spent 90 minutes looking for it, and finally found it at the air QD for the doser purge valve (lucky day). I didn't know what it was so spent an hour searching and finally found a service bulletin that explained what it was. Delete to the rescue! Capped the line. The truck has NEVER held air like this EVER! Hope all are healthy. PS: This is on a 2250. The purge valve is behind the ECM and it's harness and about 25 other air lines on a '12 cascadia. |
