| Water pump - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Water pump (/showthread.php?tid=6381) |
Water pump - Mrkentee - 07-10-2020 I’m changing out my coolant. The original water pump has over 1,000,000 miles on it. It’s not leaking. Should I change it anyway? I’m getting an OTR from Fleetpride. Any thoughts on those? Thanks. RE: Water pump - Waterloo - 07-10-2020 I would go OEM on that... I have had a few OTR parts that weren't quite up to snuff... Hit and miss on quality. RE: Water pump - JimT - 07-10-2020 Whats the typical life expectancy of a water pump? A guy I knew locally had one seize up on him, took out the engine. Don't want to end up being that guy... RE: Water pump - Signature620 - 07-10-2020 I've had to grind down the impeller on an aftermarket ISX water pump to stop it scraping in the housing. They're just built to a price. ISX water pumps usually start leaking out of their weep hole or the bearings collapse and get quite noisey. I've never heard of one seizing up. Cummins will sell you a brand new water pump cartridge and oring. Very simple to replace. |
