| Best radiator flush product. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Best radiator flush product. (/showthread.php?tid=6418) |
Best radiator flush product. - BLOODSWEATTEARSMX13 - 07-19-2020 I am due for a radiator drain and refill. I was curious about the best radiator flush product available today. Any suggestions? RE: Best radiator flush product. - Signature620 - 07-19-2020 Most radiator flush products are acid or alkaline-based. I would recommend avoiding them unless you think there's some serious scale build up or you've had contamination like oil/fuel in your coolant. RE: Best radiator flush product. - Rawze - 07-19-2020 i have used a couple different ones. - I have had best luck so far with cummins restore. RE: Best radiator flush product. - BLOODSWEATTEARSMX13 - 07-20-2020 (07-19-2020 )Signature620 Wrote: Most radiator flush products are acid or alkaline-based. I would recommend avoiding them unless you think there's some serious scale build up or you've had contamination like oil/fuel in your coolant. Copy that. Thank you for your reply. RE: Best radiator flush product. - BLOODSWEATTEARSMX13 - 07-20-2020 (07-19-2020 )Rawze Wrote: i have used a couple different ones. - I have had best luck so far with cummins restore. Copy the "Cummins Restore" product. I will give it a try. Appreciate the reply Rawze. RE: Best radiator flush product. - the missing link - 08-04-2020 On old farm equipment with lots of scale buildup . What would you guys think of using crl . |
