A few metal shavings in fuel filter cartridge. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: A few metal shavings in fuel filter cartridge. (/showthread.php?tid=6431) |
A few metal shavings in fuel filter cartridge. - Meanwhile - 07-21-2020 My truck has the Paccar cartridge style fuel filter, normally I change it around 7,500 miles because it get pretty dark. The last two times I noticed a few metal shavings. These pieces I find are sliver like and not like flakes or chunks. Could this mean anything other than the filter is doing it’s job? RE: A few metal shavings in fuel filter cartridge. - Hedley - 07-21-2020 Metal shavings in your fuel filter could mean that your fuel pump is starting to fail, you might want to have a good Tech look at it before you contaminate your fuel system. RE: A few metal shavings in fuel filter cartridge. - Meanwhile - 07-21-2020 Thanks! I guess I better plan on a couple days off and get it checked. |
