| Pro Star TC issue - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Pro Star TC issue (/showthread.php?tid=6458) |
Pro Star TC issue - AMPMChatt - 08-03-2020 Good Day gents. I have a question about a 2014 pro star where the TC light stays on, but goes out whenever you press the brakes. Code SID 55 FMI 7 stop lamp switch not detected goes off and on also when pressing the brakes. Bendix system Brakes lights work as should Stop lamp switch replaced still has same issues. Stop lamp switch has 12 volts going to it. Wires all look good, just confused on where the brake switch wires lead. I have checked the plugs going to the EC 60 Bendix brain and the body controllers and have not found the wires. Any help would be much appreciated. RE: Pro Star TC issue - Mr Hagg - 08-03-2020 If my memory serves me you should have a few switches for the brake. one being for the brake lights the other for cruise and then one more for traction controll the later 2 are normally closed RE: Pro Star TC issue - AMPMChatt - 08-09-2020 Thank, I replaced all switches and light went off when I replaced the one for cruise control. Thanks for the info! |
