Help loosing power on high gears!!!! - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Help loosing power on high gears!!!! (/showthread.php?tid=647) |
Help loosing power on high gears!!!! - jimeneztrans84 - 07-19-2016 Just got my truck back today from oil pump and main bearings. They did a fresh oil change too, they used delvac and baldwin filters. Did a regular 180 round trip today and truck didn't feel the same. When I would down shift it felt like the gear wouldn't last and had to downshift an extra gear. Truck is a 2011 cm2250 450 502,000 miles. Can the baldwin fuel filter affect my power? RE: Help loosing power on high gears!!!! - in2trux - 07-20-2016 I run Baldwin filters and have never had any problems but that is on an 871. Maybe the new bearings? After they get some run time engine should loosen up a bit and spin a little easier. |
