| Trans leak - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Trans leak (/showthread.php?tid=6477) |
Trans leak - Neighbor - 08-08-2020 Can't seem to find any info on if the slave cylinder bolts on the side of an Eaton 18 speed trans needs thread sealant on them like the ones on the rear for the range selector do?? Rtlo18918b is the model number for trans. RE: Trans leak - snailexpress - 08-08-2020 (08-08-2020 )Neighbor Wrote: Can't seem to find any info on if the slave cylinder bolts on the side of an Eaton 18 speed trans needs thread sealant on them like the ones on the rear for the range selector do?? Rtlo18918b is the model number for trans.I think RoadRanger has all transmission service manuals. You can download from Eaton site. |
