fault code 639 2015 prostar isx - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: fault code 639 2015 prostar isx (/showthread.php?tid=6513) |
fault code 639 2015 prostar isx - boondocker - 08-16-2020 Hello guys I went away on vacation for 2 weeks, had the master switch off. I went to start it today cranks but wont fire. I tightened the cables still no run. It will rattle with a little either. Any suggestion please. I see it is a message for the ecm RE: fault code 639 2015 prostar isx - Waterloo - 08-16-2020 Smack the ECM with a screwdriver handle while someone tries to start... Also, there should be a separate power wire to it with an inline fuse, check that too. RE: fault code 639 2015 prostar isx - Rawze - 08-17-2020 is the electric fuel pump running when you turn the keyswitch on? |
