Fault Code: 1145 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Fault Code: 1145 (/showthread.php?tid=6525) |
RE: Fault Code: 1145 - walterk - 10-29-2023 The saga continues.... I found this Cummins bulletin: https://static.nhtsa.gov/odi/tsbs/2021/MC-10190753-9999.pdf It seems that a water contamination could be a culprit here as well. RE: Fault Code: 1145 - Rawze - 10-29-2023 (10-29-2023 )walterk Wrote: The saga continues.... Then make sure your fuel water separator is doing its job and that any water in the bottom of it is drained/checked weekly. |
