Oil leak, between flywheel housing and block - Printable Version
+--- Thread: Oil leak, between flywheel housing and block (/showthread.php?tid=6587)
Pages: 1 2
RE: Oil leak, between flywheel housing and block - Chamberpains - 09-10-2020
So these flywheel housing don't have to centered using a dial indicator?
RE: Oil leak, between flywheel housing and block - Signature620 - 09-10-2020
They use 2 dowel rings for alignment. Most of the time they are very accurate, but it's always good practise to check with an indicator.
RE: Oil leak, between flywheel housing and block - JMBT - 03-04-2021
Signature620 had said: “I usually hit the sealing face of these housings with an orbital sander then clean and reassemble it with a light coat of Permatex Aviation Sealant on both sides of the gasket.”
What grit disc do you use with the orbital sander? I don’t want to remove too much material but want to get the surface nice and clean.
Thanks! JMBT
RE: Oil leak, between flywheel housing and block - tree98 - 03-05-2021
I don't think I would sand it but that's just me. You should be able to get it clean by scraping and using a scotch bright pad.
RE: Oil leak, between flywheel housing and block - Signature620 - 03-05-2021
Scotch pads will absolutely get them ready to refit, no problems.
I prefer to sand them as most of them have serious fretting. It leaves a nice, uniform finish without the excessive time and material loss of having the housings machined.
I use the same practice for all flat gasket surfaces of exh manifolds, front and rear housings, thermostat housings, intake manifolds, etc. Consider it a gentlemanly alternative to those 2" buff wheels people like to use.
