Isx Crankcase filter sensor high pressure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Isx Crankcase filter sensor high pressure (/showthread.php?tid=661) |
RE: Isx Crankcase filter sensor high pressure - Waterloo - 07-22-2016 (07-22-2016 )So Cal ProStar Wrote: I'm in San Diego California, about a 3hr drive from LA. That would be great if any mechanic on here could take a look at it. The truck was driven bobtail from Iowa but who knows how long it was run like that. Dr ISX is in Vegas, he is on the board here, look him up and shoot him a PM... If I were you, that is what I would do. Also, ask Rawze or Unilever for his contact info, I have not seen him on here in a bit... Might be quicker that way, as the guy is an ace on these things from everything I have seen here over the past two years... Good luck. RE: Isx Crankcase filter sensor high pressure - So Cal ProStar - 07-27-2016 UPDATE: Engine was opened up to find broken rings in every pistons. Sleeves showed signed of blow by carbon build up at the top. Pictures will be sent to warranty tomorrow and we'll go from there. Not sure if the link will work but you can see some pics of the truck and rings etc. https://drive.google.com/open?id=0B8vaRPHaqnJ3b0VoWVcxbFNUdFU RE: Isx Crankcase filter sensor high pressure - Rawze - 07-27-2016 All the liners are washed out from rust and water intrusion. -- Maybe lot rot? -- Then when it finally did get fired up it broke all the rings trying to overcome the rust? Just a guess. ============ That thing is in bad shape. You can see that engine looks very very different from mine did at just under a million miles. what a shame. RE: Isx Crankcase filter sensor high pressure - So Cal ProStar - 07-27-2016 (07-27-2016 )Rawze Wrote: All the liners are washed out from rust and water intrusion. -- Maybe lot rot? -- Then when it finally did get fired up it broke all the rings trying to overcome the rust? Thank you for sharing all your knowledge Rawze! I spent the morning watching some of your videos and it feels great to understand a little of how these engines and their components run. At least I'm getting pretty much a new engine out of this truck I haven't even done a run on. I did have one question though... When cleaning the intake tubes with carb cleaner, do you just literally spray it inside and use a brush to clean? Do you rinse it at the end and let air dry? I will check the dozer injector since the engine is all opened up and coolant is drained. Anything else I should check other than what's in you egr tune up video? RE: Isx Crankcase filter sensor high pressure - Rawze - 07-27-2016 (07-27-2016 )So Cal ProStar Wrote:(07-27-2016 )Rawze Wrote: All the liners are washed out from rust and water intrusion. -- Maybe lot rot? -- Then when it finally did get fired up it broke all the rings trying to overcome the rust? Make sure the EGr valve is operating well and check the CAC for leaks while you are at it. |
