VGT - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: VGT (/showthread.php?tid=6617) |
VGT - PinneyKW - 09-21-2020 So checked for play and it’s right and no metal flakes. So the question is how would the turbo act if the veins were clogged with soot? Would it be boosting/spooling a lot? Louder whine to it? RE: VGT - RollinCoal - 09-21-2020 (09-21-2020 )PinneyKW Wrote: So checked for play and it’s right and no metal flakes. So the question is how would the turbo act if the veins were clogged with soot? Would it be boosting/spooling a lot? Louder whine to it?they would stick Usally closed and the engine wouldn't run or even crank Kind of rare I have seen maybe 3-4 trucks do it in the last 7 years The way your truck in running in the video you sent me its going to be something simple I just cant safely say what unless I can get eyes on some data from it Could be as simple as an ecm update RE: VGT - Rawze - 09-21-2020 this may help... <iframe id="lbry-iframe" width="560" height="315" src="https://lbry.tv/$/embed/isx-inspecting-and-replacing-your-turbo/bd980df4368c3470544b0cf02c446df94ca24ebb" allowfullscreen></iframe> |
