Engine fuel 1 injector cylinder 6 fmi 7 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: Engine fuel 1 injector cylinder 6 fmi 7 (/showthread.php?tid=6672) |
Engine fuel 1 injector cylinder 6 fmi 7 - Godsplan15 - 10-07-2020 Anyone had this code? It’s an SPN 656 RE: Engine fuel 1 injector cylinder 6 fmi 7 - Godsplan15 - 10-07-2020 It’s a Cummins engine btw. 2015 KW T680 RE: Engine fuel 1 injector cylinder 6 fmi 7 - Rawze - 10-07-2020 quickerv says that if fault code 1145. Injector Solenoid Driver Cylinder 6 - Mechanical System Not Responding or Out of Adjustment I.E.> The Engine Control Module (ECM) detected a fueling timing or quantity error for the specified injector. Is the enigne de-mandated(delete)?. could be bad program. could also be something wrong with wiring or the injector. here are also some search results for this fault that have been discussed in the past... http://rawze.com/forums/showthread.php?tid=575&pid=4372#pid4372 http://rawze.com/forums/showthread.php?tid=6525&pid=57399#pid57399 RE: Engine fuel 1 injector cylinder 6 fmi 7 - Godsplan15 - 10-07-2020 (10-07-2020 )Rawze Wrote: quickerv says that if fault code 1145. Injector Solenoid Driver Cylinder 6 - Mechanical System Not Responding or Out of AdjustmentOk thank you. I will look further into it |
