| 570K mile cab mounts prostar/lonestar - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: 570K mile cab mounts prostar/lonestar (/showthread.php?tid=6683) |
570K mile cab mounts prostar/lonestar - Yauchout - 10-09-2020 i installed the pro ride xt a few weeks back and decided to do cab mounts at the same time just figured i would share some photos of what a almost 600K mile cab mount looked like incase someone was debating on if they needed to replace them RE: 570K mile cab mounts prostar/lonestar - Waterloo - 10-10-2020 How about the damper? It is time to replace at 500,000 miles... RE: 570K mile cab mounts prostar/lonestar - Chamberpains - 10-10-2020 Might as well pile on the 500,000 miles maintenance. These are 590,000 rear engine mount bushings out of my KW T660 but I imagine the life of all truck engine bushings are about the same. I couldn't see how bad they were until I got them out. The only thing visible from under the truck was a small gap in the rearside of it. Once I pulled them, the crack and smashed out rubber was seen. [attachment=7190][attachment=7191][attachment=7192] RE: 570K mile cab mounts prostar/lonestar - Yauchout - 10-10-2020 (10-10-2020 )Chamberpains Wrote: Might as well pile on the 500,000 miles maintenance. These are 590,000 rear engine mount bushings out of my KW T660 but I imagine the life of all truck engine bushings are about the same. I couldn't see how bad they were until I got them out. The only thing visible from under the truck was a small gap in the rearside of it. Once I pulled them, the crack and smashed out rubber was seen. How hard are they to change I suspect mine need done also RE: 570K mile cab mounts prostar/lonestar - Chamberpains - 10-10-2020 My T660 was easy enough to jack the pressure off them at the flywheel housing. Then unbolt the engine mount off the engine and pulled them out. This may be a tall task for a compact truck like a prostar. If your in there doing a clutch, that is a great time to do them. |
