| Opinions on MAG1 15w 40 oil - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Opinions on MAG1 15w 40 oil (/showthread.php?tid=6703) |
Opinions on MAG1 15w 40 oil - PuroCumminsPower - 10-17-2020 I have a mechanic I know that uses this oil. I was wondering if anyone has used it and opinions on it. I use Shell Rotella 15W 40 with gallon of gear oil. Thanks. RE: Opinions on MAG1 15w 40 oil - Rawze - 10-17-2020 (10-17-2020 )PuroCumminsPower Wrote: I have a mechanic I know that uses this oil. I was wondering if anyone has used it and opinions on it. I use Shell Rotella 10w 40 with gallon of gear oil. maybe send an oil sample off to a lab? RE: Opinions on MAG1 15w 40 oil - Waterloo - 10-17-2020 Found this... All the Private Label Brands Warren Distribution Makes, If You're Interested https://www.bobistheoilguy.com/forums/threads/all-the-private-label-brands-warren-distribution-makes-if-youre-interested.320097/ |
