| Cummins ISL won’t start - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cummins ISL won’t start (/showthread.php?tid=6806) |
Cummins ISL won’t start - DD12 - 11-25-2020 I have a 2005 KW with an ISL 350. It turns over until the batteries are drained and will only crank with starting fluid. Once running seems fine other than smoking. Turn off and try to start right back, nope. RE: Cummins ISL won’t start - Signature620 - 11-26-2020 Do you have any other details? This could be caused by a whole range of things such as: Air in the fuel Plugged filters Plugged pickup Shattered fuel pump plungers Failed fuel pump actuator Low ECM voltage Do you have access to Insite? RE: Cummins ISL won’t start - Rawze - 11-26-2020 (11-25-2020 )DD12 Wrote: I have a 2005 KW with an ISL 350. It turns over until the batteries are drained and will only crank with starting fluid. Once running seems fine other than smoking. Turn off and try to start right back, nope. - Check fuel pressure is above its minimum required while cranking. Not sure about ISL, but the older ISX engines, they would do this (before common rail) whenever the shaft for the gear pump would snap internally. - Won't start for s$it, but once running, it would spin the snapped shaft enough to keep the fuel pressure up. - Only indication is that when checking fuel pressure during cranking, it never gets up to the required minimum pressure. |
