Oil viscosity 60 series 12.7 - Printable Version
+--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72)
+--- Thread: Oil viscosity 60 series 12.7 (/showthread.php?tid=6974)
Oil viscosity 60 series 12.7 - 2dlb - 01-27-2021
I have a 12.7 60 series Ddec Iv with a recent o/h. We installed a full tilt manifold hopefully to get passed the cracking problem with the stock ones that seam to break annually and a 171702 bw turbo. Calibration was done by a reputable tuner. Since then every oil change at 15000 fails drastically the vi index of 15w40 gets to 80- off the scale. Oxidation and nitration are high as well. Does anyone have any thoughts on this. Is the 1702 to big for this set up.
RE: Oil viscosity 60 series 12.7 - Rawze - 01-27-2021
Put the factory programming back in and see if it still fails the oil analysis. Bad programming can do a lot of damage. Ensure it is not bad programming.
RE: Oil viscosity 60 series 12.7 - 2dlb - 01-27-2021
Is mommaburt around. I’ve been trying unilevers for a awhile and get no response
