| CM870 Pull File from ECM - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM870 Pull File from ECM (/showthread.php?tid=7021) Pages: 1 2 |
CM870 Pull File from ECM - 2dlb - 02-08-2021 Hi Guys. I have an ECM and have borrowed a bench harness. I can hook up ok with insite and can see a list of active faults, i assume cause its not hooked up to the truck. How do i go about copying the ecm file to email it to Rawze. Any help would be great ive never done it before. Thanks RE: CM870 Pull File from ECM - tree98 - 02-08-2021 You need c@term to pull a copy of the program, insite won't do it. RE: CM870 Pull File from ECM - 2dlb - 02-08-2021 thanks, i do have cterm but still wont open. as well i cant clear the codes i assume because the truck is not hooked up. or is there another file i need RE: CM870 Pull File from ECM - tree98 - 02-08-2021 You need the right engine configuration file. RE: CM870 Pull File from ECM - 2dlb - 02-08-2021 I found enf is that right for a 870 RE: CM870 Pull File from ECM - tree98 - 02-08-2021 Honestly I can't remember and I can't check at the moment. RE: CM870 Pull File from ECM - Blott4 - 02-12-2021 (02-08-2021 )2dlb Wrote: I found enf is that right for a 870 Any news on this? I would also be interested in knowing how to pull a file. RE: CM870 Pull File from ECM - Chamberpains - 02-12-2021 You need to search out and aquire calterm and the directions you seek are in what the internet knows as mama's m ilk money files. RE: CM870 Pull File from ECM - Peashooter67 - 02-19-2023 That’s for the cm871 not a cm870 ! Will this still work for an cm870? |
