C15 Acert filled to double its oil capacity - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: C15 Acert filled to double its oil capacity (/showthread.php?tid=7057) |
C15 Acert filled to double its oil capacity - Redland1 - 02-18-2021 My brothers C15 was filled to double its oil capacity and started for about 15-20 seconds when it as shutoff when the engine didn’t sound right.long story short one person was supposed to be draining the oils and changing filters while the other filling with new oil on a few trucks.Truck doesn’t want to start back up and it was drained till it was at max level.What could have happened to the engine? TIA. RE: C15 Acert filled to double its oil capacity - Rawze - 02-18-2021 The oil foaming up?... could have possibly spun a bearing. when u say "does not want to start up" .. more detail would be helpful. Will it turn over? -- does it turn over very slowly? ... Does it crank normally but just will refuse to fire off? .. is it harder then normal to turn the engine over by hand? ... etc. RE: C15 Acert filled to double its oil capacity - Redland1 - 02-18-2021 It’s cranking normal just refuses to fire off. RE: C15 Acert filled to double its oil capacity - Rawze - 02-18-2021 (02-18-2021 )Redland1 Wrote: It’s cranking normal just refuses to fire off. maybe a fuel issue then. fuel filter sucking air? RE: C15 Acert filled to double its oil capacity - Redland1 - 02-18-2021 It’s cranking normal just refuses to fire off. RE: C15 Acert filled to double its oil capacity - Waterloo - 02-20-2021 Ever get this figured out? RE: C15 Acert filled to double its oil capacity - 03maxpower - 02-21-2021 Hate it when people don’t update the fix. RE: C15 Acert filled to double its oil capacity - Rawze - 02-21-2021 What I would like to know is what kind of moron does not check the dip-stick level before cranking the engine after an oil change?? RE: C15 Acert filled to double its oil capacity - Redland1 - 02-22-2021 It ended being the fuel filter sucking air like you said.My brother told the guy helping us out to put 11 gallons because that is what it always takes so he assumed everything was good. |
