Another code - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Another code (/showthread.php?tid=7092) |
Another code - JAsaro - 02-25-2021 Spn 5319-31 RE: Another code - JAsaro - 02-25-2021 Oh yea it’s says In complete region replaced my filter during the summer RE: Another code - JAsaro - 02-25-2021 Maybe the DPF differential pressure sensor? RE: Another code - Rawze - 02-25-2021 maybe post a couple pics of the regen history as well. RE: Another code - JAsaro - 02-26-2021 I can’t I don’t have insite RE: Another code - Rawze - 02-26-2021 (02-26-2021 )JAsaro Wrote: I can’t I don’t have insite inline6 from china on ebay is your friend. RE: Another code - tree98 - 02-26-2021 Without insite your just pissing in the wind and nobody here is gonna be able to do much to help you. RE: Another code - JAsaro - 02-26-2021 (02-26-2021 )Rawze Wrote:(02-26-2021 )JAsaro Wrote: I can’t I don’t have insite Yes I know I just keep forgetting to get one going to order one today RE: Another code - JAsaro - 02-26-2021 (02-26-2021 )tree98 Wrote: Without insite your just pissing in the wind and nobody here is gonna be able to do much to help you. I know just keep forgetting to order |
