finally was able to hook up insite today - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: finally was able to hook up insite today (/showthread.php?tid=7100) |
finally was able to hook up insite today - Bward - 02-27-2021 I was finally able to run insite today after waiting forever for computer parts. I connected to the ECU and did a lot of looking around. what are some major items to look for/ to do in the program. I was able to screen shot this.[attachment=7576] How do I read this? RE: finally was able to hook up insite today - Rawze - 02-28-2021 lot of idle time but otherwise, not too bad. RE: finally was able to hook up insite today - Bward - 02-28-2021 Is there anything else I need to look at while I'm in there? RE: finally was able to hook up insite today - tree98 - 02-28-2021 Aftertreatment history, it's on that same screen at the top of the list. You want all the numbers on the far right to average 3.0 or under. If they are higher it's time to bake the cans. RE: finally was able to hook up insite today - Bward - 02-28-2021 Mine are @1.2 . Is there a way to copy the ECU and use it as a simulator? I would like to tinker with it at the house and get to know the program better. RE: finally was able to hook up insite today - schISM - 03-01-2021 (02-28-2021 )Bward Wrote: Mine are @1.2 . Is there a way to copy the ECU and use it as a simulator? I would like to tinker with it at the house and get to know the program better. Open INSITE and at the bottom of the screen there’s a drop down menu for choosing different datalink devices to connect with. There should be a couple different engines in that list as well you can connect to and use as a simulator. |
