Which sealant for flywheel housing gasket? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Which sealant for flywheel housing gasket? (/showthread.php?tid=7112) |
Which sealant for flywheel housing gasket? - JMBT - 03-03-2021 Is the preferred sealant to use for the flywheel housing gasket still (Permatex aviation sealant)? RE: Which sealant for flywheel housing gasket? - Rawze - 03-03-2021 the gasket is designed to be installed without sealant from what I understand. here is the procedure... https://quickserve.cummins.com/qs3/pubsys2/xml/en/procedures/132/132-016-006-shopas-mixar5.html?q=flywheel%20housing That being said, it is not unusual for someone to dust a tiny bit of "Anaerobic Flange Sealant" on the gasket to help it seal... https://amzn.to/3sRFQu5 RE: Which sealant for flywheel housing gasket? - Signature620 - 03-03-2021 Permatex is my preferred sealant. Holds well and cleans off easily next time. Don't pour it on, just a lick on both sides of the gasket. |
