code - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: code (/showthread.php?tid=713) |
code - Vilos09 - 08-03-2016 Has anyone seen this code?? MID128 SID380 FM11 I guessing it has something to do with regen system on my ISX Any info welcome.... RE: code - Rawze - 08-03-2016 (08-03-2016 )Vilos09 Wrote: Has anyone seen this code?? Maybe I got it wrong, but the error I found says... FC-1664: Aftertreatment 1 Diesel Oxidation Catalyst Missing - Error Exists. ???? not sure if that is the right translation for the code. Maybe check to see if someone stole it from out under your truck? -- Or perhaps a broken exhaust pipe between the back of the turbo and the DOC unit? RE: code - Vilos09 - 08-03-2016 I replaced DOC almost a year ago exactly with an aftermarket one. Cost was about 1000 bucks less than the OEM DOC from Cummins. RE: code - Vilos09 - 08-03-2016 Turbo was replaced in Feb. all pipes good as far as i can tell. How long before the thing clogs up?? last regen was this morning. i only drove about 350mi today.. RE: code - Unilevers - 08-04-2016 (08-03-2016 )Vilos09 Wrote: I replaced DOC almost a year ago exactly with an you said alot right there. RE: code - hhow55 - 08-04-2016 Aftermarket DOC, BIG NO, No!!!!!!!!! RE: code - snailexpress - 08-04-2016 Need check with insite sensors on the aftertreatment. If one of them is not working this code will set. Probably bad wires. RE: code - Vilos09 - 08-04-2016 dealer in Des Moines wants 325 for 2hr diagnostic. I going to check out Power Diesel instead. Google gives them good reviews... RE: code - Vilos09 - 08-04-2016 That was Pro Diesel... |
