| Egr measurment venturi - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Egr measurment venturi (/showthread.php?tid=7131) |
Egr measurment venturi - PuroCumminsPower - 03-07-2021 Can someone please chime in on how to stop air from leaking from the "Front EGR connection tube" I replaced it a couple months ago. Replaced the gasket as well. I rechecked for air leaks by presurizing system like Rawze shows and found a air leak at the Front EGR connection tube. What else could I do to stop air leak? https://quickserve.cummins.com/rtgraphics/english/service/11/c/11c00191_lg.png Its number 6 on diagram. I stripped one of the bolts #5 on diagram. Anyone know the part # for the bolts? RE: Egr measurment venturi - Rawze - 03-07-2021 (03-07-2021 )PuroCumminsPower Wrote: Can someone please chime in on how to stop air from leaking from the "Front EGR connection tube" I replaced it a couple months ago. Replaced the gasket as well. I rechecked for air leaks by presurizing system like Rawze shows and found a air leak at the Front EGR connection tube. What else could I do to stop air leak? I can only assume you mean this.... [attachment=7597] ========== - They like to leak there. If it is leaking at the gasket/flange itself, then you just need to ensure it is nice and flat, it has a proper fit, and that the gasket is good. If it is leaking around the tube itself where it meets the top of flange ... this is more common. They are horribly welded and only press-fit. Find a welding shop that can braze it up good all the way around without distorting it. also por-15 paint it with a thick coat or 2 when finished. ========= (assuming you live in a foreign country where the stuff is allowed)... If the engine is ehemm... "de-mandated" ... then there should be a block plate at position #1. more info on this... http://rawze.com/forums/showthread.php?tid=2451&pid=21629#pid21629 RE: Egr measurment venturi - PuroCumminsPower - 03-07-2021 (03-07-2021 )Rawze Wrote: ...I do remember that I have the bolt and washers in the Egr Venturi pipe like you recommend. I never installed the plate though. Is there somewhere I can order one? I remember a lot of members had them built. RE: Egr measurment venturi - Rawze - 03-07-2021 maybe order a 304-stainless hockey-puck from Mr.hags? RE: Egr measurment venturi - PuroCumminsPower - 03-07-2021 (03-07-2021 )Rawze Wrote: maybe order a 304-stainless hockey-puck from Mr.hags?Do you mean Mr Hags? Just want to make sure. RE: Egr measurment venturi - hhow55 - 03-07-2021 (03-07-2021 )PuroCumminsPower Wrote: Do you mean Mr Hags? Just want to make sure. Yes |
