| Pressure protection valve - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Pressure protection valve (/showthread.php?tid=7135) |
Pressure protection valve - boondocker - 03-09-2021 Has anyone had trouble with this in the secondary air tank. It feeds my air purge and I believe my fan hub supply. Below freezing my fan stays engaged and I get code 3490 for the purge air actuator every time the truck does a passive regen. Has anyone tried cleaning this valve out as I believe it may be sludged up. Thanks Steve RE: Pressure protection valve - Rawze - 03-09-2021 what year, make, model truck, engine, etc.. some history would likely help. RE: Pressure protection valve - boondocker - 03-09-2021 (03-09-2021 )Rawze Wrote: what year, make, model truck, engine, etc.. some history would likely help. Sorry 2015 prostar isx |
