| Isx cm870 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Isx cm870 (/showthread.php?tid=716) |
Isx cm870 - 808allstarr - 08-04-2016 Check engine light goes on/off sometimes for awhile sometimes for a few minutes. Got code 197 and have changed sensor on reseveroir but still throws code. Water levels are good when i check. RE: Isx cm870 - Nilao - 08-04-2016 Friend of my me had this issue. Come to find out the coolant had formed a coating over the contacts so it would read erroneously. Never mind, just re-read you changed the sensor RE: Isx cm870 - Nilao - 08-04-2016 Check your ecm plugs to make sure they're not loose. I have seen them vibrate the retaining screw out enough to make some terminal contact intermittently. RE: Isx cm870 - 808allstarr - 08-08-2016 So yea i wrote i changed sensor but it was quite some time ago. Recently checking plug to sensor there was a little water in plug and contacts did have some kind of build up on them. So should i change sensor again cuz i dont think its supposed to be wet in there? And after a new sensor is put in and ecm plugs checked and those turn out fine any other other things to check? |
