| Laptop for insite - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Laptop for insite (/showthread.php?tid=7277) |
Laptop for insite - JAsaro - 04-19-2021 I’m thinking about changing my laptop because it keeps freezing when I’m checking stuff what’s a good laptop and would I need a sign in password RE: Laptop for insite - Rawze - 04-19-2021 a $300 dollar or so cheap laptop from wal-mart with win10 on it is all most ppl need for just insite/calterrmm. if u think its just software issue, .... Why not just wpe the one you got, re-install winblows from scratch, and get rid of all the spyware, etc.. and make a fresh install? RE: Laptop for insite - JAsaro - 04-19-2021 (04-19-2021 )Rawze Wrote: a $300 dollar or so cheap laptop from wal-mart with win10 on it is all most ppl need for just insite/calterrmm. I did that before I installed the insite and it keeps doing the same thing RE: Laptop for insite - Chamberpains - 04-19-2021 I dont know what version of insite you have but I had a freezing problem when I 1st started using v7.6.2 I found the SP5 (Serivice pack 5) patch and it cured my freezing problem. |
