Coolant level low, coolant fine. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Coolant level low, coolant fine. (/showthread.php?tid=7358) |
Coolant level low, coolant fine. - suined - 05-14-2021 Coolant sensor wire should have 5v, im getting 3.6v. Truck shows check emgine for low coolant.. Any ideas? RE: Coolant level low, coolant fine. - SquareOne - 05-14-2021 Did you ohm the sensor to see if it was within range? RE: Coolant level low, coolant fine. - Rawze - 05-14-2021 there are lots of other posts of the past about low coolant alarms on trucks when the coolant level is fine.. it is a common issue. Here are some other threads.. maybe take a read thru some of them... http://rawze.com/forums/showthread.php?tid=4633&pid=39667#pid39667 http://rawze.com/forums/showthread.php?tid=3073&pid=26429#pid26429 http://rawze.com/forums/showthread.php?tid=3396&pid=29328#pid29328 http://rawze.com/forums/showthread.php?tid=2832&pid=25580#pid25580 i am sure there are more of them. RE: Coolant level low, coolant fine. - Wildcard - 05-14-2021 Any body know of an issue with the coolant level sensor Freightliner uses causing issue or not working well with OAT coolants? |
