Volvo truck d13 check engine fault - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Other truck related Help... (/forumdisplay.php?fid=71) +--- Thread: Volvo truck d13 check engine fault (/showthread.php?tid=736) |
Volvo truck d13 check engine fault - sbtrucking - 08-10-2016 Help please, Check engine fault just came on, its 2016 volvo 780 with volvo d13 engine and I shift Codes SA 16 DTC P25A913 SA 16 DTC P220164 Are they critical? Thanks in advance RE: Volvo truck d13 check engine fault - RPM1 - 08-10-2016 Don't know adout the Volvo but the mack has a Lil what looks like a turn sigenal under right side of stearing wheel that u can axas fault codes then look up in one the books that came with the truck or do a online search through Volvo or mack RE: Volvo truck d13 check engine fault - axe - 08-10-2016 800-528-6586 Volvo phone number. They will tell you what code is. Wore them out when I had Volvo with ISX. RE: Volvo truck d13 check engine fault - kryten - 08-11-2016 SB - I found this on the Volvo website. https://volvotrucks.vg-emedia.com/ProductDetail.aspx?ProductId=10514 Click on view file and all the codes will come up in a 50 -60 page document. Your first one doesn't appear to be in there but if (and that's a huge if) I'm reading the list right the second one looks like the #1 NOX sensor. RE: Volvo truck d13 check engine fault - DrivingZiggy - 08-14-2016 On my Volvo, you can scroll through the menus until you get to "Diagnostics." Then you choose "ECU." Then the faults may come up. Sometimes it's more complicated and you have to call Volvo. |
