cm870 excessive black smoke under power - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: cm870 excessive black smoke under power (/showthread.php?tid=741) Pages: 1 2 |
RE: cm870 excessive black smoke under power - Rawze - 08-17-2016 (08-17-2016 )Runt Wrote: Probably the Turbo Actuator. Some refer to it as the waste gate. Just a word of caution for those who own CM870's out there ... Unplugging your EGR and not having the ECM re-programmed properly for it can make for a lot of excess turbo temps. Once a year? --- You got a pyro gauge on the Manifold like in my videos? --- Sounds like it is exceeding 900 degrees to me,.. that or you are not letting it cool to below 400 degrees before you shut it off. Just some thought on it... Rawze RE: cm870 excessive black smoke under power - Runt - 08-18-2016 Thanks to the Forum, I have indeed watched the videos and installed a pyrometer earlier this year. I did in fact unplug the EGR when it was the thing to do years back 08/09..., but it has been plugged in since the last EGR replacement in 2010? I can't say that I always let the turbo cool down to 400, but I ALWAYS try. The 1 on it now has been on well over a year thus far. Most dealerships tell me it's bad quality control wherever they make them. Runt RE: cm870 excessive black smoke under power - Rawze - 08-18-2016 (08-18-2016 )Runt Wrote: Thanks to the Forum, I have indeed watched the videos and installed a pyrometer earlier this year. Thanks for the feedback. Everyone learns and benefits from others experiences. what does your pyro stay at most of the time? Boost levels? RE: cm870 excessive black smoke under power - Runt - 08-18-2016 Mostly between 450 and 550. Boost on a pull with 43k still below 40lbs. usually about 32-35lbs. I know your against cruise control, but I set it and forget it.... I really don't run much over 62mph anymore. I would like to get to do a light tuning and get rid of engine clutter. Gotta say....she's been a good motor RE: cm870 excessive black smoke under power - Nilao - 08-18-2016 I don't think Rawze is against cruise control. I think he's said he'd use it on flat stretches but he uses his foot in the hills to keep boost under 20psi. Oh, and the tunes over 485 tend to get really hot while on cruise in the mountains on hard pulls also. Which is why he recommends the 485 tune as the biggest to put in if you plan on using cruise a lot. RE: cm870 excessive black smoke under power - Runt - 08-18-2016 Thanks Nilao.. Yea, I would tune it for 500 or below. It's at 475 now, maybe something to clean it up so it'll run a strong 465.. |
