W900 ambient air temp sensor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: W900 ambient air temp sensor (/showthread.php?tid=7431) |
W900 ambient air temp sensor - smorgan87 - 06-01-2021 2019 w900 x15. Has anyone had one these ambient air temp sensors built into the mirror harness go bad? Is there a way to install a normal temp sensor? Mines bad and the harnesses are on natl backorder as well as have a 300$ price tag!!! RE: W900 ambient air temp sensor - HillbillyISX - 06-02-2021 Mine went bad on my 2013 Pete, it took a little while to change, the wire runs through the mirror arm to the cab, the connections are plug in, both the mirror and the cab, I took the cover off the bottom arm where it bolts to the cab and and it exposed the wires, I pulled the plastic nut off the bottom of mirror pulled out the wires and plugged the color coded wires up, hooked the new harness to a thin wire and ran through the rubber tube going into the cab (rub dishwashing liquid on the harness it helps it go through the rubber sleeve) I had to take my dash panel off on the left to see where to connect, it has the same connections in the cab, mine was pretty crowded in the dash, but, I managed. As far as replacing the sending unit with something else, I'm not sure, I'm no mechanic but I think that sensor communicates with the ECM along with another sensor on the intake. Hope this helps..... RE: W900 ambient air temp sensor - tree98 - 06-02-2021 (06-01-2021 )smorgan87 Wrote: 2019 w900 x15. Has anyone had one these ambient air temp sensors built into the mirror harness go bad? Is there a way to install a normal temp sensor? Mines bad and the harnesses are on natl backorder as well as have a 300$ price tag!!! Guess your off to the boneyard. RE: W900 ambient air temp sensor - Waterloo - 06-02-2021 You can always make a new harness, I have done that before on my ProStar... |
