SmartNav gauge change/add - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: SmartNav gauge change/add (/showthread.php?tid=7437) |
SmartNav gauge change/add - Skman - 06-04-2021 2016 Pete 389 isx15 I just got this truck and have a few things I've been trying to fine tune. One problem is that I've got no diff temperature gauges. No mechanical and none on the SmartNav. Is it possible to get them added into the SmartNav system by Peterbilt? I have no more room on my dash for gauges...other than a pyro gauge when it comes in. I do have a couple redundant gauges though. I have a mechanical trans temp and manifold pressure gauge...but I also have them on the SmartNav. I'd like to remove those from Smart NAV and add the diff temps...if possible. Anyone ever done it? RE: SmartNav gauge change/add - smorgan87 - 06-04-2021 I dont recall diff temps being an option in esa. Are the temp probes even installed in the diffs? RE: SmartNav gauge change/add - schISM - 06-05-2021 (06-04-2021 )Skman Wrote: 2016 Pete 389 isx15 I’d start by checking for the diff. temp. connectors in the wire loom at the back of the frame. If they’re present then it’s just a plug and play affair, you’ll only need to buy the temp. sending units and the gauges.The gauges are on the J1939 backbone so you can plug them in anywhere in the dash you have an opening and enable them with ESA and your good to go. If you don’t have the connectors out back though your pretty much SOL. |
