| CM 870 head? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM 870 head? (/showthread.php?tid=748) |
CM 870 head? - Big D - 08-13-2016 Just replaced head,but didn't know I needed to swap the plug on the left side bottom of head. Core was returned last week. Anybody know if a regular pipe plug will work,if so what size? If not anyone know the part number? Motor is a reman so quickserve is limited as far as small parts. RE: CM 870 head? - hhow55 - 08-13-2016 Can't help you on the plug, you did not install. Btw, hope you did put some anerobic sealant, on the oil return drain. I didn't, and I have an oil leak, at the rear part of the head. Oh well, live and learn RE: CM 870 head? - Rawze - 08-14-2016 (08-13-2016 )Big D Wrote: Just replaced head,but didn't know I needed to swap the plug on the left side bottom of head. Core was returned last week. Anybody know if a regular pipe plug will work,if so what size? If not anyone know the part number? Motor is a reman so quickserve is limited as far as small parts. I show part number 3678838 (M33 x 2.0) plug. It is in the parts list for the head but not referenced in the drawing. |
