Is 100% biodiesel okay in Cummins 871? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Is 100% biodiesel okay in Cummins 871? (/showthread.php?tid=7560) |
Is 100% biodiesel okay in Cummins 871? - PuroCumminsPower - 07-16-2021 One of the places I fuel at I noticed went from 5-20% biodiesel to know has a sticker that says 100% biodiesel. Is this okay for my Cummins 871 with M M tune? Thanks. RE: Is 100% biodiesel okay in Cummins 871? - Rawze - 07-16-2021 just make sure you have a 10 micron davco installed to catch the higher ashphaltine rates in the fuel. RE: Is 100% biodiesel okay in Cummins 871? - smorgan87 - 07-16-2021 Long as the dpf has been africanized. Just be prepared for significantly less mpg and as rawze said use the 10 micron filter and have spares ready. RE: Is 100% biodiesel okay in Cummins 871? - Chamberpains - 07-16-2021 My cm870 loved bio fuel. It got better fuel mileage but it went screaming through fuel filters. I haven't had an opportunity to get any in my cm871 yet. Where are you getting 100% bio? RE: Is 100% biodiesel okay in Cummins 871? - PuroCumminsPower - 08-03-2021 I fuel at 3 different locations in California. W.H Breshars. Atwater, CA ;Modesto, CA ; Newman, CA all 3 are now 100% biodiesel. A month ago it was a blend of biodiesel. RE: Is 100% biodiesel okay in Cummins 871? - PuroCumminsPower - 08-03-2021 Will 100% biodiesel effect my 2010 THERMOKING Apu? Started acting up on me today. Hoping it’s not because of the 100% biodiesel. RE: Is 100% biodiesel okay in Cummins 871? - JimT - 08-03-2021 It should be noted also that Fleetguard has different water separator filters for use with biodiesel fuels. Not exactly sure what the difference is, other than I think a green o-ring instead of black. Probably not a big deal for typical 5-20% blended fuel, but if you're running 100% bio then you might want to look into it. |
