06’ 9900i - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: 06’ 9900i (/showthread.php?tid=7568) |
06’ 9900i - Luckyjayb - 07-20-2021 Trying to make sure my leveling valve is set correctly. What should the distance be from the bottom of the air bag plat to the bottom of the frame. Standard suspension, not the “z” bar. Thanks for the input RE: 06’ 9900i - Rawze - 07-20-2021 The height of the cab in the back from the bottom of the cab to the frame is supposed to be the same height as it is in the front. |
