Brass Fitting ID - Printable Version
+--- Thread: Brass Fitting ID (/showthread.php?tid=7576)
Brass Fitting ID - RocketScott - 07-22-2021
Anybody recognize the markings on this fitting?
This isn't the actual fitting that I need but the roll mark was easier to get a picture of
It's not Parker. I was in their store yesterday and they had no idea
RE: Brass Fitting ID - snailexpress - 07-22-2021
Looks very close
https://trademark.trademarkia.com/logo-87152246.html
RE: Brass Fitting ID - RocketScott - 07-23-2021
That looks like a newer/ish company
This came off an '89 Peterbilt
Possible that the company isn't around anymore, or was sold to someone else
RE: Brass Fitting ID - smorgan87 - 07-23-2021
What kinda fitting is it? Flare? Compression? Pipe? Shouldnt be oring on a 89.
The fitting I'm looking for is a test probe port that goes on top of the thermostat housing
1/8' NPT threads with a 1/8" NPT plug in the top to close it off. There's a grommet inside that seals the probe when it's inserted
I can find all sorts of test ports in 1/4" NPT but nothing in 1/8"
For now I just replaced it with a 1/8" male to female fitting with a 1/8 pipe plug in the top to seal it off
